E4OD Selenoid Buzzing - B&M Shiftplus
Has anyone after installing this kit on their F150,
noticed a buzzing sound coming from their transmission selenoid(s) when coming to a stop or idleing at a stop in drive?
If so, have you found out from B&M what's causing
these selenoid(s) to buzz.
I'm afraid of cooking the selenoids!
HI!... I wouldn't advise you to continue using any kind of electronic shift improver. They have been proven to fry your tranny's solanoids much of the times there is a solanoid failure. Are you running the shift improver on it's highest setting a lot? If you want fast, firm shifts then my advise to you is to get a shift kit (TRANSGO). A shift kit physically make your transmission produce more line pressure safely.
