Speedo
Old Feb 16, 2003 | 09:37 PM
67camaro's Avatar
Speedo
Went to a 35x12.50 tire on 01 S-crew, now the speedo is off about 5 mph. Is their anything that can be done to correct the problem.
Thanx
Old Feb 17, 2003 | 10:07 AM
B-Man's Avatar
Cool
Most speedos are off by 2 or 3 mph anyway. I believe Mike T. can make adjustments with a MicroTuner or a SuperChip.
There are also "black boxes" available on the Internet that you put in-line with your tranny's electronics to modify the speedo readings. Most I've seen are $100 or so.
If you don't have a chip, put the money towards that and get the added chip benefitts as well...
Old Feb 17, 2003 | 03:51 PM
DoggieDoc's Avatar
I installed and Electronic Ratio Adapter on my mustang. After a swapped in a 3.73 gear I was able to adjust to within 1%. I am sure it can be used on the F series too but you'd have to find a tech with wiring diagram to figure out which wire to splice to.
The company is Abbott Enterprises.
http://www.atrol.com
