More Towing Questions
Old Jun 18, 2002 | 10:26 AM
HrlyDr's Avatar
Question More Towing Questions
Ok, most of you guys have prolly had an eyefull of towing question posts by now. But I'm a motorcycle guy, not a truck expert. This site looks/works just like www.cruisebikes.net BTW for any bikers here...
I have a 1988 F-150 XLT. 5.0EFI, 4x4, 4" lift, rancho suspension, 15" alumininum wheels, 33 x 12.5 tires. I have NO IDEA what my axle ratio is, and the dealer tells me he can't decode the VIN of a truck that old....old? Damn...Still feels/looks new after 105,000 miles. I guess I keep forgetting it's an '88.
To my questions: Does anybody know what the axel ratio might be, or where I could find it? I might be able to still read the door jamb sticker, but the tab on the rear is long gone since the cover was replaced with an aftermarket unit. Also, can I pull a 4790lb(dry) / 6800 GVWR camping trailer plus have my bike (500lbs) in the bed?
Thanks.
Old Jun 18, 2002 | 12:36 PM
MitchF150's Avatar
Unhappy
I'm afraid I won't be much help on your gear ratio, but the door jamb would be the only other place to look. Look for something labeled "AXLE".
As far as will your setup tow that trailer.......... I'd say that you will be over weight if it's almost 5k dry!! That ol' 5.0 will not like it at all, especially with 33" tall tires. You'd have to have something like 4.56 gears to even consider it. Then, you'd have to consider the length of the trailer and your trucks wheelbase. If you tow a long trailer with a short wheelbase truck, you will have a pretty good "pucker" )*( factor going on!
I'm looking at TT right now. I'm not going to tow anything that weighs more then 5,500 #'s fully loaded, ready to camp and not more then 21' long, but that's just me. Other's will say "I tow my 26', 7000# TT all the time with no problems." That's great for them, but not for me. JMO.....
Good Luck and welcome aboard....
Old Jun 19, 2002 | 12:02 AM
suvdrvr's Avatar
If all else fails, jack up the rear of your truck so the wheels are free to turn, following all safety proceedures of coarse. Rotate your wheels one revolution, count how many rev's your driveshaft makes,ie. 3.5, 3.7, 4.1 or whatever. This will give you a ballpark figure.
Old Jun 19, 2002 | 10:31 AM
BeastRider's Avatar
With one wheel raised, the number of driveshaft rotations will be double. So, you'd be looking at 7, 7.4, and 8.2 turns.
