Towing with 18" low profile tires??
Old Mar 10, 2002 | 12:13 PM
BlueBlood's Avatar
Question Towing with 18" low profile tires??
Anybody tow with low profile tires.I tow a 4500lbs travel trailer and am looking at a set of Lightning 18x9.5 wheels with 285/60R18 tires.Anyone know of problems with this set up? The new tire load rating is about the same as stock and overall tire height is within 1/2 "
Old Mar 10, 2002 | 02:29 PM
Ian N's Avatar
I am looking at the same thing. The Michelin Pilot LTX is actually a "XL" tire with about a 1000# extra capacity per tire.
The lower sidewall should make the truck tow better since there is less sidewall height to cause sway.
Ian
Old Mar 10, 2002 | 10:03 PM
FamilyRide's Avatar
Yep, what Ian said.
Old Mar 12, 2002 | 05:04 PM
texan_eagle_sco's Avatar
Exclamation towing with low profile tires
There is one very important thing to consider with those tires. They are probably a softer compound and will wear quicker than a normal tire. Yes the sidewalls will eliminate sway, but in the process are they scubbing that inertia from the trailer off in side-ways tire grinding. Those would be expensive tires to burn-off like that. IMHO
2001 XLT SCrew
White / Graphite INt.
Cast Alum. Wheels
Capt. Chairs
5.4L / Auto
3.55 Rear
Old Mar 12, 2002 | 05:35 PM
hmustang's Avatar
I think you will be alright if you go with that set up.
Old Mar 15, 2002 | 08:39 PM
HeirBorn's Avatar
My X is lowered with 295/45/18's and I tow a 21' wakeboard boat
and it tows fine. No problems.
https://www.f150online.com/galleries...y.cfm?gnum=938
