secondary gas tank??
Old Nov 20, 2001 | 08:11 PM
motorob's Avatar
Is there such a thing available aftermarket for the f150? I remember way back when, my parents had a '74 f250 with two extra saddle tanks one in front of each of the two rear wheels. It would be nice to get a bit longer range when towing.
Old Nov 20, 2001 | 08:57 PM
Old Timer's Avatar
Hi Motorob...
Know what you mean. Havent really looked into it, but in my TL mag. i saw this...
transfer flow.....1-800-442-0056 (aux. gas tanks etc.)
www.transferflow.com
Good luck OT
Old Nov 20, 2001 | 09:36 PM
Sidewalk's Avatar
It is common for some Ranger owners to pull out a fuel tank from a Bronco II and put it in place of the spare tire (stock location for BII). If you don't mind relocating your spare to the bed, you could add on a 23 gallon tank. It would only require a little fabrication work, and you could get a valve brand new from JC Whitney.
Old Nov 21, 2001 | 10:32 AM
ron993's Avatar
you might want to check with your local laws before though
i know here in texas the tank has to be approved, then checked for leaks and all that good stuff
well this is for a unleaded gas tank
with a diesel tank you just throw it in the back, hook it up and go
Old Nov 22, 2001 | 01:21 AM
model a's Avatar
I do not understand why Ford dropped the dual gas tank option. Around this area, 90% of the old bodystyle trucks had dual tanks. It was great when towing or just a little insurance to prevent running out of gas. 38 to 40 gallons sure beats 25 gallons when you are getting 9 mpg towing.
Anyone in Dearborn listening?
Model A
Old Nov 25, 2001 | 07:57 PM
ron993's Avatar
my 1992 f150 had 2, 15 gallon tanks
so you really did not gain that much
Old Nov 26, 2001 | 05:10 PM
ronhop's Avatar
Several companies make a truck bed box that has an aux tank in it that goes from 12 to over 50 gallons. I believe that JC-Whitney sells both steel and aluminum versions that are plumbed into the fuel system or have an accessory hand-pump to transfer fuel from the aux tank to the main tank. I've seen various versions of these on several late model F-150s that are used for work trucks in the area I live in. Maybe check out www.jcwhitney.com. I don't think I would try and mount an aux tank in place of the spare for safety reasons... One good rear-end hit and you could be in trouble.
Old Nov 26, 2001 | 09:44 PM
Sidewalk's Avatar
It was safe enough to come out of the factory that way...
Bronco II's have the tank where the spare should reside because it has too short of a wheel base to put a tank alongside the drive shaft like other trucks.
Old Nov 27, 2001 | 12:52 AM
signmaster's Avatar
It's nice at times, but you don't really need it. Sometimes there is such a thing as overkill.
My '95 holds 37 gallons in the two factory tanks. Even with crappy towing mileage much more than you want to drive without a stop anyway.
Old Nov 29, 2001 | 07:47 PM
motorob's Avatar
yeah, I thought about the safety issues w/ a tank aft of the rear axle... I figured it wouldn't be a big deal, cause I'll only ever fill it up when I'm towing the trailer.
As far as range, I can get maybe 200mi or so on a tankful, but the problem is I end up having to either fill up at 100mi, or go further but be stuck paying $0.40/gal more.
I'll probably end up going with one of those in-bed tanks, which pump into your regular gas tank. It seems that not being hooked into the pressurized fuel system makes the tank much cheaper. I've got a long bed, so loosing a ft or two of bed length isn't a big deal for me.
