transmission temp gauge
Old Sep 26, 2001 | 01:19 PM
roland.h's Avatar
Question transmission temp gauge
Hello all, I am wanting to add a transmission temperature gauge to my f150, has anyone done this? If so what gauge did you use and where did you mount it? Where on the transmission did you put the sender? This is on a 2001 super cab 4x4 w/ 5.4
Roland
Old Sep 26, 2001 | 07:01 PM
FamilyRide's Avatar
Do a search on transmissions. I recall several threads in the last month or so. I haven't done it yet, but when I find a good place to mount gauges that looks good, I'm planning on it.
Old Sep 27, 2001 | 11:26 AM
EddieC's Avatar
Gauge Mounting Place
I understand that there is a kit where you can mount such guages in the "A" pillar. That is all I know.
Old Sep 27, 2001 | 08:16 PM
model a's Avatar
Gauge Pod
www.gaugepods.com/lightning.htm has pictures of the pillar mount. You may want to look at www.autometer.com , www.egauges.com , or even www.westach.com for some aircraft quality gauges. I've been looking at trans. temperature and vacuum gauges and these sites have many pics and specs. Some gauges have color filters to change the gauge lighting so it matches factory lighting. I ain't tryin to sell nuthin er ah um I receive no monetary or other consideration for posting the above URLs.
Model A
Old Oct 2, 2001 | 01:57 PM
Former Sponsor
Hi roland.h,
Most people are using the A-pillar "pods" to mount their gauges in these F-150's on the A-pillar, where your grab handle is.
With regards to probe placement, I'm glad you asked, as that is a very important consideration. In some transmission oil temperature & auxiliary cooler kits for these F-150's, they tell you to locate the temperature probe *after* the transmission cooler, which is dead wrong, as you'll only get the absolute lowest termperatures like that, after the fluid has already passed thru the cooler. That tells you next to nothing about the temperatures actually present inside the transmission, which is what you need to know, that's the purpose of the gauge in the first place.
You want to locate your probe as close as possible to the point of exit, meaning where the transmission fluid exits the transmission, *before* it enters any cooler(s), so that you get the highest possible readings, and so you know just what temperatures are actually present inside the transmission.
There are plenty of good gauges, etc., and I'm sure those links posted in another response should be helpful.
Good luck!
