Trailer brake issue
Old Jun 26, 2014 | 10:30 PM
Charlotteguy's Avatar
Trailer brake issue
Help! I'm pulling out what hair I have left. I have an 18 foot flatbed car hauler. Tandem 3,500 pound axles with brakes on 1 axle. I tow it with a 2007 F 250 that has the factory controller. When I check the trailer brakes at the start of a trip they lock up tight so I dial back the gain. I check them again and it feels like nothing is working. I dial back up and it feels like they are barely there. The wiring all appears to be ok (including the accidental severing I caused and soldered back together). Another thing I've noticed once or twice is that on heavy rain they seem much more responsive. I don't think it's the truck because I pulled a different trailer the other days and the brakes worked great. I'm new to this, please help! I don't know what brand the brakes are and haven't found a way to adjust them. I found a slot on the back side that a cover pops off and I can see a spring in there but no apparent way to adjust them. Ideas???? Thanks all!
Old Jun 28, 2014 | 11:12 PM
MitchF150's Avatar
Might have to check the trailers ground wire??
Good luck!
Mitch
Old Jun 29, 2014 | 12:13 AM
Ground looks good. No other electrical issues with the trailer. Buddy of mine checked it out with a voltmeter. He said it looks like I'm getting 11-12 volts and it might be a mechanical issue with the brakes themselves. I can't find any way to adjust them though. Maybe have to remove the wheels to get to it?
Old Jun 29, 2014 | 12:18 PM
MitchF150's Avatar
The brakes should have a slot in the back where you move a 'star wheel' to tighten up the shoes to the drum.
But, pulling the drums if you've never seen how electric brakes are setup would be a good thing to do anyway.. While you are doing it, you can repack the bearings and have that task out of the way too.
When I adjust the brakes on my TT after pulling the drums, I set them so they just slightly drag a bit, but still spins a couple of times on a hard spin..
Good luck!
Mitch
