2012 trailer plug question
Old Nov 8, 2012 | 03:32 PM
bigricky3's Avatar
before I wind up tearing it apart, I thought I should ask.
How do you get constant 12V out of the #4 (black) prong on the 7 wire plug? Is there a setting I need to change, or a fuse I need to add, or is it not wired to anything? I want to have a 12V constant to run the lights & charge the battery in my racing trailer.
Thanks guys.
Old Nov 8, 2012 | 07:17 PM
avfrog's Avatar
The aux wire is only hot when the key is on.
Old Nov 8, 2012 | 10:10 PM
bigricky3's Avatar
Doh! I shoulda thought of that!
Old Nov 15, 2012 | 09:00 AM
bigricky3's Avatar
Tried it, still didn't work... Any ideas?
Old Nov 15, 2012 | 07:21 PM
avfrog's Avatar
Old Nov 15, 2012 | 07:24 PM
avfrog's Avatar
You should be able to use the aux also for a constant 12v source too. Use a voltage meter or test light to find what has voltage and what doesn't. If you can find voltage at the conection at all, then start looking for a blown fuse or bad relay.
