Towing Package?
HOW CAN YOU TELL IF YOU HAVE A TOWING PACKAGE? I BOUGHT MY TRUCK USED AND WONDER IF THEY TOOK THE HITCH OUT. IT HAS A 7-WAY PLUG ON IT AND THE RELAYS FOR THE 12 CHARGE AND BACK UP LIGHT RELAY, OR DO ALL THE F-150'S COME WITH THIS? THANKS.
All of them come with that connector. The tow pakage comes with a little different one.
You could also look for a trans cooler as that might be an indication. You should be able to tell if the hitch was removed. Look at the frame for bolt/mount marks on the under side and inside just at the back close to the hitch.
