Equalizing hitch
Old Jun 21, 2001 | 10:29 PM
ET's Avatar
ET
Post Equalizing hitch
Can anyone explain the proper way to set up an equalizing hitch on a trailer.
Do you hook the arms before the weight of the trailer goes on the ball mount?
Thank you
99 F250 LD 5.4 ltr
Old Jun 22, 2001 | 09:34 AM
ron993's Avatar
Post
what you do is this
1.lower the trailer down onto the ball
2.latch the trailer to the ball
3.lift the trailer back up some
4. then attach the equilizer bars
5. then lift the jack
i am pretty sure that is about it
i have a 5th wheel so i do not remember totally how to do it.
Ronnie Hartzog
Houston, Tx
2000 F250 PSD
1973 VW THING
1996 New Vision 5th Wheel
2000 Kawasaki Prairie 4x4
Former Rides
1999 F150 Sport with FQR
1992 F150
1989 Chevy S10
Old Jun 22, 2001 | 11:57 AM
Ian N's Avatar
Post
Ron is right - if you try to connect the bars after putting the load on the truck, you will never get it to connect because the load is too great. For the same reason, take the load off the bars before you try to disconnect them. There is a lot of energy in those spring bars!
For advise on how to properly setup the hitch (very important to avoid sway), check out http://www.can-am-rv.com/cantow1.htm
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani/Gibson Cat Back Exhaust, Superchip Flipchip, PIAA Superwhites
