Adding A 7 Pin Connector
Old Apr 23, 2001 | 05:44 PM
Penhall's Avatar
Question Adding A 7 Pin Connector
Question for you all.
I have a 99 F150 XLT SC 4x4 that I bought off the lot WITHOUT the trailer towing group.
I am now interested in towing a 19' Travel Trailer. Bolting on the CIII hitch reciever is not a problem but was wondering about the wiring.
My truck came stock with the standard 4 pin flat connector but I now want to add the 7 pin unit. What is involved? Is the truck pre-wired or is it going to be a splice job?
Help/Hints/Tips?
Regards
George
1999 F150 SC 4x4 XLT
5.4 Litre
Old Apr 23, 2001 | 07:12 PM
GIJoeCam's Avatar
Post
Call the dealership... tell them you need the 7-pin pig-tail. It should plug into the main harness at the same point the 4-pin does. You might also need the 7-pin to 4-pin adapter kit to get the relays and the adapter for electric brakes. I don't know if the 98 came with them or not... someone else might know for sure. On my 2000, I had to install 2 additional relays under the hood in the fuse block for the charging circuit and the back-up circuit for the trailer plug. I know the 97 and 98 trailer tow package had those already installed.
The wiring harness is the starting point, though... Dealership will have it, but a junk-yard might also.
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof($1000), built 11/99 picked up 10/00!Clear Corners($36), Manik Stainless Steel 1-piece brush guard($700), Custom CB wiring, Uniden PC76-XLW CB radio($100) with K-40 Magna-Mount antenna (for now [$40]), 1 set of 165 watt KC Daylighters (for now... more on the way... $140) Fog Light Switch mod(free!!!), Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbar w/ 2" stainless steel ball($80), Gray Tek Style Soft Tonneau Cover($250), Gray Line-X Bedliner ($450).
List of planned mods: Clear tails, torsion bar tweak, bug deflector, Chrome ORP rims.
93 Probe GT teal, OE rims painted to match, bone stock drivetrain, leaky exhaust.
Old Apr 25, 2001 | 08:46 PM
rockycarl's Avatar
Post
I am looking at having one hard wired. The harness from the dealership is $88. I can have one hard wired at a hitch shop for $45. I was going to do it myself, but the factory harness has another harness behind it that goes up to your tail lights so cutting the harness is out of the question. It was too confusing for me, so I am taking it in on Monday.
