Brake controller wiring question
Old Aug 27, 2000 | 03:56 PM
GTD/KAD's Avatar
Question Brake controller wiring question
Greetings,
I just got my new Supercrew with the Class III tow package. It came with a wiring harness and relays for the brake controller.
I am looking at my wiring harness supplied with the towing package and I see a 5th wire called ILLUMINATION FEED (apparently for the running lights on my trailer) but my brake controller (Tekonsha Commander 9010)only has 4 wires. The ILLUMINATION FEED is supposed to cut into the headlight wire somewhere.
Since it came with the trailer wiring already hooked up at the receiver, shouldn't the running lights have a connection already wired to the receiver connection?
BTW, I know how the controller needs to be wired but I wouldn't want to have to cut into any underdash wiring if I don't have to.
Also, Tekonsha recommends that the ground wire be directly wired to the battery. What is wrong with the ground wire supplied with the towing harness? Isn't it a direct line already? Should I connect the Ground wire directly to the battery?
Thanks.
  • Oxford White
  • XLT
  • 4x4
  • 5.4l
  • 3.55 LS
  • Class III tow
  • Keyless entry
  • Power bench
  • Cab steps
  • Ford bedliner
Old Aug 27, 2000 | 08:19 PM
Tina's Avatar
Thumbs up
Greetings to you too
I went over to the diesel board to do some research on this. This is basicly what I came up with:
About the hooking up directly to the battery for the ground wire. Most of the guys over there that use the Tekonsha hook directly to the battery. One guy had problems, he even used a dedicated #10 wire but it didn't solve his problems. He had to get a completely different brand of controler. They only talked about the Tekonsha Envoy, the Voyager and the Sentinel.
About the brown illumination wire: on my controler (Activator II) it was simply left alone. I think it's for controlers that have dimming type lights on them. You hook up w/the other 4 wires but not the 5th (brown)wire. If you need any help with what wire color hooks to what color, I can tell you how my Activator II hooked up. I just don't know what colors your controler uses so I don't know how much good that would do for you.
2k F250 CC SWB 6 speed 4x2 Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, rear privacy glass
TT Pkg, Class IV hitch, sliding rear window, running boards, mud flaps
265/75/16 AS OWL tires, am/fm/cassette/cd, rechargable MagLite
Clarion APA 5240 amp, Memphis speakers:Components front, 5x7 rear, 10"sub
SuperChip, Stepshields, Ventshields on windows, rubber bed mat
rugged liner bedliner on tailgate, quick disconnect jumper cables
unaFORDable (decal on tailgate)
Old Aug 28, 2000 | 07:36 AM
Firezap's Avatar
Cool
Tina is correct the brown wire is from the controller. My Powerstop has a blue light showing the manual activation button.
GOLD RUSH
'99 F150 XLT SC SB 4x2 Harvest Gold
Factory[*]5.4[*]3.55 limited slip[*]Trailer towing package[*]In-dash CD player
Aftermarket[*]Ford Beanie bear[*]Slip on extender mirrors[*]Powerstop brake controller[*]Covermaster C1000 topper with wing[*]BugflectorII[*]Ventvisors (front&rear)[*]3 www.f150online.com decals[*]Ford Lumi Logo[*]Steelhorse Billet grill[*]Ford hitch cover[*]Yellow wire loom[*]Hyper White head light bulb[*]Painted to match AVS slotted taillight covers[*]Ford system 4 alarm[*]Clear turn signals[*]"Blazer" strip reflectors under tailgate[*]FORD script antenna painted to match[*]Next who knows???
<A HREF="http://www.firezap.url4life.com" TARGET=_blank> </A>
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank> </A>
firezap@f150fanatic.com
firezapper@home.com
[This message has been edited by Firezap (edited 08-28-2000).]
Old Aug 28, 2000 | 08:23 AM
Orval's Avatar
Post
Yes,
I would agree with the last replies the illumination wire is for the light in the brake controller. My manual activation bar lights up so you can see it at night. If your controller does not have this then don't use that wire.
Old Aug 29, 2000 | 05:57 PM
GTD/KAD's Avatar
Post
Thanks,
My controller (Tekonsha Commander) has only 4 wires Ground, Battery, Stop light and Brake so I won't need the ILLUMINATION FEED. I looked at skyjet's site at: http://www.over.to/SuperCrew/
again and I see that he had info about the ILLUMINATION FEED wire.
I don't know why I didn't see it before. Probably cause I was eyeballing his SCrew.
  • Oxford White
  • XLT
  • 4x4
  • 5.4l
  • 3.55 LS
  • Class III tow
  • Keyless entry
  • Power bench
  • Cab steps
  • Ford bedliner
