7 pin question
Old Jan 6, 2010 | 02:46 PM
never ending's Avatar
7 pin question
i have a 97 f150 with a tow package. i have the 7 round and 4 flat. i tryed to tow a fishing boat but when we checked the lights all i had was break lights. is there a fuse that went bad under the truck or is there a bad wire or wires that i need to swap out or should i get a whole new plug.
thanks
Old Jan 6, 2010 | 03:12 PM
ChrisT's Avatar
Are you sure the trailer's wiring and bulbs are all in working order? I'd bet the truck isn't the problem.
Old Jan 6, 2010 | 03:30 PM
MitchF150's Avatar
There are different fuses for parking and turn lights I believe. There is an additional fuse box under the hood. I think the "sticky" post had a diagram of it?
It's also in your owners manual and if you don't have that, it can be downloaded from here.
https://www.fleet.ford.com/maintenan...ls/default.asp
Mitch
Old Jan 6, 2010 | 04:52 PM
jpf150's Avatar
Im with ChrisT because me and my dad had the same problem and it was the trailer. But make sure you do check all the fuses.
Old Jan 6, 2010 | 05:47 PM
yeah i know it's the truck. we hooked it my to a buddys truck and it all worked fine. i will have to look under the hood. thanks guys.
Old Jan 6, 2010 | 08:57 PM
avfrog's Avatar
With my 4 pin, the left turn signal doesn't work, but it does with the 7 pin???
Old Jan 6, 2010 | 09:09 PM
Glen R's Avatar
It is probably a fuse under teh hood. I lost running lights on my trailer this past summer. Still had brake, and turn, but no marker lights. It ended up being the fuse under the hood.
Old Jan 6, 2010 | 09:30 PM
ok so im goingto look under the hood in the next few days. is it the same lay out as 36fan put on the sticky for his 2000. i have a 97. thanks for the help
Old Jan 6, 2010 | 09:33 PM
Glen R's Avatar
Mitch
I wouold think it is similar. You can go to the above site, and download the one for your year model.
Old Jan 11, 2010 | 11:31 PM
ok so i looked under the hood today when i changed my plugs and wires and i look for the fuses. i found that maxi 16 witch is a 40 amp was blown. would this be my problem. thanks
Old Jan 12, 2010 | 08:50 AM
Glen R's Avatar
From the owner's manual on above page.
16 40 Trailer tow battery charge and stop/turn lamps
So I would say this was probably the problem. If you don't have a trailer to hook up and test, you can test with a meter, or they sell cheap little plug in testers at most auto parts places.
