towing help
Old Dec 1, 2008 | 08:54 PM
basscaster46's Avatar
towing help
Friend`s I have a 2006 supercrew 5.4 355 limited slip 20 inch wheels.
Was wondering if I could pull a 5765lb travel trailer. It is 32.9 long that is dry weight. Book say`s it will pull 13,000 gross ,8000 max trailer.I`m thinking it might be too much for this setup. What about changing gear ratio to 3.73 or 4.10? Or maybe going to the standard wheel size instead of the 20`s?
chainslinger
Old Dec 1, 2008 | 09:45 PM
yetti96's Avatar
Page 194
http://www.motorcraftservice.com/pub.../06f12og4e.pdf
Crew Cab 4x2 (138.5” wheelbase)
5.4L (with 18”
or 20” tires) 3.55 axle ratio
Maximum GCWR-lb. (kg) 13500 (6123)
Maximum trailer weight-lb. (kg) 8000 (3629)
Crew Cab 4x4 (138.5” wheelbase)
5.4L (with 18”
or 20” tires) 3.55
Maximum trailer weight-lb. (kg) 7700 (3493)
Crew Cab 4x2 (150.5” wheelbase)
5.4L (with 18”
or 20” tires) 3.55
Maximum trailer weight-lb. (kg) 7900 (3583)
Crew Cab 4x4 (150.5” wheelbase)
5.4L (with 18”
or 20” tires) 3.55
Maximum trailer weight-lb. (kg) 7600 (3447)
Old Dec 2, 2008 | 06:53 AM
APT's Avatar
APT
That will be over 7k ready for a trip. That's more than I want to tow with any 1/2 ton, yet people do it. Also, with that kind of length, you want a long wheelbase truck. Do you have 2WD or 4wd? 5.5" bed or 6.5"?
Old Dec 2, 2008 | 07:08 PM
acadianabob's Avatar
I think that is too much for your truck. We tow about 5,000 pounds and that is PLENTY.
Old Dec 3, 2008 | 10:55 AM
You are going to exceed the GCWR before you exceed the max trailer weight spec. Load up the truck the way you would to take a trip and go get it weighed, then subtract that from the max GCWR to get the *TRUE* max trailer weight.
Old Dec 6, 2008 | 04:32 PM
Yall are proably right way to much for 1/2 ton.
Chainslinger
Old Dec 13, 2008 | 01:10 PM
pacificnw's Avatar
5765 MAX might be OK... the dry weight probably isn't much help in figuring what the actual weight is back there. Find a scale close by and get the actual. No sense guessing when you are "on the edge" so to speak.
