500 miles and a successful trip. The 24 ft trailer pulled flawlessly. I had it at 85mph briefly with zero wobble. I stayed at about 65-70 the whole way.
BigMan..... Please keep in mind that the tires on your TT are only rated for 65 MPH. Please be safe. I did read that you can run a bit faster if you increase the air pressure but I am not about to attempt it. A tire failure or 2 at 85 MPH would not be a scenario that I would want to try to control. It sounds like your setup is stable though. We also towed 200 miles this weekend. The weather was perfect and towing was, once again, without issue. Have a good time and be safe.
