2006 F-150 Factory Hitch
Old Apr 4, 2008 | 06:06 PM
bartlowj's Avatar
I have a 06 F-150 4x4 SuperCrew that I bought brand new. I got it with a 5.4, 3.73 rear end, and the trailer tow package. According to Ford Web Site: Includes Class IV trailer hitch receiver, 7-pin wiring harness, upgraded radiator and upgraded auxiliary transmission oil cooler (requires 4.6L or 5.4L Triton® V8). My issue is the rating sticker on the actual hitch shows only a 500# tongue/5000# trailer weight for a weight carrying hitch (900/9000 for weight distributing). Has anyone else seen this? I am getting ready so start pulling my new boat this spring that will be around 6300# on a tandem axle trailer. Tongue weight should be less than 600#, probably closer to 500. Any thoughts or suggestions as to if I should be worried about the factory hitch?
Old Apr 4, 2008 | 06:28 PM
kingfish51's Avatar
The tongue weight should be 8-15% of trailer weight loaded. With that it makes it over 500, even at 8%. You will be far better off with a WD hitch. Also need brakes on the trailer.
Old Apr 4, 2008 | 06:47 PM
bartlowj's Avatar
I was under the impression on a boat trailer the tongue weight was normally 6-10% on average of the total weight. The trailer is a new Rolco Custom Signature tandem axle trailer with surge brakes. I've been considering a Weight Distributing hitch, but I've been hearing bad things about using them with surge brake trailers.
http://www.rolcotrailers.com/custom.html
Old Apr 4, 2008 | 07:51 PM
kingfish51's Avatar
Some hitches will work.
http://www.equalizerhitch.com/produc...patibility.php
Also, "technically" surge brakes are not legal per DOT.
But as the article states, they will continue to be used.
http://www.redtrailers.com/ShowArticle.asp?id=2
Old Apr 5, 2008 | 02:54 AM
Get a WD hitch, a brake controller, and a trailer with real brakes, not surge brakes. Ideal tongue weight is 12% of the total trailer weight.
Old Apr 5, 2008 | 11:32 AM
kd4crs's Avatar
X2, that is the right way to go.
Old Apr 5, 2008 | 11:55 AM
pacificnw's Avatar
In my state (can't speak for others) trailers with weight exceeding 3,000 pounds must have real brakes... electric or hydraulic are your choices?
Old Apr 7, 2008 | 12:50 PM
bartlowj's Avatar
Would you want to take the tension off of the spring arms before dropping the boat in the water? I would think that would be alot of tension supporting the 4500# of boat on the trailer and then immediatley not having a load on the trailer I would think could lead to some problems.
