vibration while towing
Old Sep 17, 2007 | 02:17 PM
STUACE's Avatar
Just picked up a new 16' car hauler. On my way back from Anchorage the back end of my truck had a serious vibration between 50 and 60mph.
First thing I did when I pulled into town was get the wheels on my truck balanced and rotated. Still vibrates. Today after work I am puting the track on a lift and checking u-joints, wheel bearings and rotors for any problems. The next thing I suppose I'll do if I dont find anything is balance the wheels on the trailer.
So, am I overlooking anything? Im driving down the Alcan Hwy in a week to Washington and I need to have this straightened out.
Adam
Old Sep 17, 2007 | 04:23 PM
red06f150's Avatar
It COULD be the torque converter shuddering from being between gears. Do you notice at certain RPM's or is it jsut between 50-60?
Old Sep 17, 2007 | 04:53 PM
STUACE's Avatar
Just between 50-60mph. It did it with and without the TC being locked up. Im really leaning towards a u-joint or rotor issue but I wont know for sure til this afternoon.
I think I noticed my truck doing it today on my way into work(without trailer). Im not sure. The roads out here are not the best.
Old Sep 17, 2007 | 05:14 PM
kingfish51's Avatar
Are you sure it isn't the trailer causing the vibration? It could be transfered through the hitch and frame.
Old Sep 17, 2007 | 05:17 PM
jmt0645's Avatar
do you have a LS rearend , i had a vibration from the rear when i first started to pull my 27' RV. after a month of this i took it to the dealer and they replaced the clutch pack in the rearend and the vibration stopped.
Old Sep 17, 2007 | 05:36 PM
STUACE's Avatar
Well, Im not sure if its the trailer. I plan to balance the wheels on it if nothing else works out. Nothing seems bent or shifted. I havent measured the axles yet to see if they are square.
The little voice in my head tell me its the truck. I will know tonight when I get it on the lift. I hope it something easy like a u-joint.
I appreciate the help though--keep it coming.
Old Sep 17, 2007 | 05:38 PM
STUACE's Avatar
Yeah, its a LS. What kind of vibration did you get? Did it only come at a certain speed?
I have reletively new 4:10 gears, so I hope it isnt that.
Old Sep 17, 2007 | 06:16 PM
red06f150's Avatar
did you put the gears in, or have someone do them? I am assuming they are not stock. If they didn't put them in perfectly it could be causing the vibration.
Old Sep 18, 2007 | 08:24 AM
kingfish51's Avatar
Do you have vibration if you are carrying a load in the bed? If not, with the very stiff frame the F150 has, I would not be surprised if the trailer was transfering vibrations to the truck.
As far as LS, any vibration from it is normally just when starting out or in a turn.
Old Sep 18, 2007 | 09:16 AM
BIG_BLUE_FX4's Avatar
Do you use your parking brake when parked? I had an '04 F150 before I bought my SD, and had a vibration issue with mine. The parking brake would not release completely and cause an extreme shudder at the speeds you are talking about. If I am not mistaken, there was a TSB on the parking brake issue.
Also, some other member here did a write up with pics when he fixed his. If I find it, I will link it.
Here it is.
https://www.f150online.com/forums/sh...ght=rear+brake
Old Sep 18, 2007 | 12:18 PM
NoseDive's Avatar
Did you have a load on the trailer at the time. My 20' open car hauler will transfer transmitts vibrations/shudder back to the truck when empty, it seems to bounce due to it not being loaded. Once my jeep is on the trailer, the vibration/shudder completely goes away.
Robbie
Old Sep 18, 2007 | 12:51 PM
STUACE's Avatar
Thanks for all the comments thus far.
I had the truck on the lift last night and everything checked out ok. The u-joints, hubs, rotors and driveine all seemed ok. I had the mechanic here at work take a look and he gave me a thumbs up.
The parking brake issue is a unrelated but real problem. I have had it not release completely and heat up my rotors until blued and needing replacment. I didnt know there was a tsb on it however. The freaking dealiership here is crap. They didnt even want to warranty the damn thing. Anyway, I digress.
The trailer is the problem now. It could have just been because it was unloaded. Or I still need balance the wheels on it. I appreciate the help.
stu
