How can I tow a 31ft travel trailer?
Can someone please give me some advice? I have a 2004 F150 Heritage (2003 body style) with the V-6 4.2L engine. I have currently bought a 31ft travel trailer dry 8,500 lbs loaded up full 9,500 lbs. I would tow empty. It has 2 axles and electric breaks. Is there any way I can upgrade my truck to pull this? I have considered buying another truck but, I like the one I have and love the payment. Could I dump some money into this one to be able to handle the weight? Some people have mentioned leaf springs, trans cooler, air bag suspension but, I don’t know where to start, what I would need or, where to go. Thank you for any help
You bought the cart before the horse. You need a bigger horse. You will need at least a F250 with a V-10 or a diesel. I pull a trailer with a dry weight of 3900lbs, loaded with options around 5000lbs. That is all my 3v 5.4 likes, except for gas. You will be suprised how much stuff you will put in the camper. Sorry I can not help with your delima, but you would far exceed the GVWR and GCWR of your current truck.
We use a 33' toyhauler and my friends Duramax
. The Duramx pulls it fine...but you know it's back there for sure when it's loaded. Down size you trailer or buy a different truck, it's the right thing to do.
9500lbs is about double what your 4.2 is rated to tow.... Best upgrade would be to buy an F-250. Short, sweet, and to the point.
To heavy for you, I had trouble pulling my last TT that weighed 6400 lbs empty and 7200 lbs full, while it made the trip it was a real challenge and that was with my 5.4 engine, besides that you will be way over the total carrying limit for your truck much less one with a V8, my truck is rated at 7200 lbs, you TT is already over that.
I am always for pushing the limits of ones truck to see what it could do. But this is way too extreme. Your truck probably wont even last 5 trips towing a load that heavy. Every part of that truck is going to be pushed way past the limit. As others have mentioned 250 would be about perfect, although a 150, 5.4 with 4.10 gears and the trailer package could do it with some strain im sure
Originally Posted by Gotts2BMe
your best bet is to go shopping for a 7700 series F-150.
