Can I pull this?
Old Oct 19, 2006 | 06:49 PM
ajhf150's Avatar
Yes, add up the (real) tongue weight, all passengers, and all cargo that you intend to haul in the truck and in the bed of the truck. Also, when calculating the tongue weight, need to add in items that will be in the very front of the camper in the cargo storage areas, this will also add some weight to the tongue. My ex-truck had really nice 20 inch rims and low profile tires and that hurt my payload capacity.
I traded up to a 2006 F-250 V10 FX4 Crew Cab with 4.30 gears, now I can load up like crazy and be well under this trucks payload. The difference on the sticker price between the F-150 and F-250 was only $2,000.
https://www.f150online.com/galleries....cfm?gnum=6941
Old Oct 22, 2006 | 10:34 AM
Fjkiss's Avatar
You should be ok pulling it BUT you should CK out the brakes
that much TT needs good brakes. no mater how fast you go you still have to STOP
Old Oct 22, 2006 | 01:15 PM
wakborder76's Avatar
Yea I'll definately check out the breaks on it before any long trip. They should be good to go though. I towed my boat around this weekend and its about 7000lbs loaded and the truck pulled it with no problems and brought it to a stop alot faster than the yukon we have ever did.
Old Oct 23, 2006 | 05:08 PM
SRockwood's Avatar
Originally Posted by HumboldtF150
BAH! Throw that in the bed!
What, and end up like this guy?
Old Oct 23, 2006 | 05:11 PM
HumboldtF150's Avatar
SWEET
Old Oct 23, 2006 | 05:36 PM
Brian M's Avatar
I pull at KZ Frontier 2505. It weighs about 5000lbs empty and has a total axle weight of 7000lbs. I tow with tanks empty but with some gear. Probably weights closer to 6500lbs if it is going to be a long stay.
Truck tows it fine. Still get 10mpg too! Far more stable than when I towed this rig with my Sequoia.
I looked at 3/4 tons......but for the 8 times a year that I tow the camper, that means the other 350 days a year I would have to be driving one of those big ole things every day. Besides....wouldn't fit in my garage.
I have used an F250 one time to move this trailer about 30 miles. I will tell you that it handled it no better than my 150....but then again it was a gasser.
Hook up and enjoy.
Old Oct 28, 2006 | 02:25 PM
pacificnw's Avatar
Originally Posted by Colorado Osprey
I think the general consensus by most who post on this forum whould say if you can hook it up, you can pull it.
By putting a trailer loaded of 8,000lbs on your truck, technically no you have not broken the max tow weight, but you have probably broken the GCVW, Gross Combined Vehicle Weight, which is the maximum weight that the vehicle with the trailer attached is designed to travel safely down the road.
By people who tow daily, the acceptable and safe towing limit for an F150 with a trailer is around 5,000lbs. Yes they will tow larger...but poorly.
That opening remark was pretty funny... and all too true.
Colorado is right on. I think 5k is a comfortable tow for an F-150. If you have a 4x4 with tow package, better gears, etc., you might be able to get close to 6k and still feel safe, have some margin, stay under your weight capacities, etc. But anything more than that is 3/4 ton time.
Old Nov 14, 2006 | 06:28 PM
nightranger's Avatar
I have pulled this all over east tennessee and the smokey mountains... not real fast mind you but it pulls well and stops well also...https://www.f150online.com/galleries....cfm?gnum=4704
