tow bar troubles
Old Apr 30, 2006 | 11:47 PM
stevenbaty's Avatar
tow bar troubles
i have a 95 f150 302 e40d 5000lbs 3.55 diff pulling a 77 cj7 304 gmt350 at qaudtrec transfer reduction gear box with 33x11.5 ats it dog tracks like a b****h and pushes my truck around in the turns any suggestions.
Old May 1, 2006 | 03:35 AM
chester8420's Avatar
Grease the steering mechanisms on the cj7 and check the U joint bearings on the front axle. A stiff U joint bearing will make it track like crap. It might even slide the front tires.
Unlock the steering column, lift up the front axle, and see if you can turn the tires left and right. If you can't then you probably have a bad spindle nut, or a frozen U joint bearing.
Been there, Done that
Old May 3, 2006 | 11:53 PM
stevenbaty's Avatar
u-joint bearing wears that i havent had a chance to tear apart a fourwheeldrive axle before? could locking the tires better help. i think it might have had a little play in it or it was off center. i tried to line it up but as i recall driving the jeep it had a lot of play in the steering would it be best to strap down the pitman arm instead of the wheel?
thanks for the help
Old May 5, 2006 | 02:56 PM
SM's Avatar
SM
thanks for the help
I'm not sure I understand what you are saying here. It sounds as if you have the front wheels and/or steering wheel locked down so the front wheels can't turn left/right. When flat-towing, the front wheels and steering wheel of the towed vehicle need to be unlocked so the front wheels can turn to follow the tow vehicle.
Does that answer what you are asking?
Old May 8, 2006 | 05:09 AM
stevenbaty's Avatar
i tried that and the first chance they got they went in the opposite direction i was going. will the just drag and straight back out or just go down the road turned
Old May 8, 2006 | 01:20 PM
SM's Avatar
SM
If everything is working right, the front wheels of the towed vehicle should track the towing vehicle fairly well...not perfectly, but fairly well. All those RVs you see going down the interstate towing vehicles behind them have the steering wheels and front wheels unlocked so the front wheels can turn. If the front wheels of the towed vehicle don't track reasonably well, something could be wrong. I would suspect the steering system and front suspension of a 29 year old CJ7.
Worn or binding wheel bearings or dragging brakes could make it pull to one side. Does the CJ have a pull to either side when driven by itself?
Old May 8, 2006 | 09:04 PM
stevenbaty's Avatar
its being restored right now but if i remember i doesnt but that was two years ago. i will check the brakes though. as far steering its anybodies guess as to a problem in that area i know the steering wheel had a lot of play in it.
Old May 9, 2006 | 12:23 AM
Your jeep should follow right behind the truck. It won't work in dirt very well, but it should track true on pavement. If it doesn't, then you either have something broken or out of alignment.
The U joint bearings that I was refering to are on the right and left front axles. They allow the front axle to apply torque to the front wheel while the wheel is turned at an angle. When a bearing is frozen up, or going out, it will make the wheels too difficult for them to track behind the truck. Usually, people don't notice front U-Joint problems until they become catastrophic, because, the power steering is strong enough to overcome the bad bearing(s).
I know all about this problem! Believe me!
Old May 22, 2006 | 09:38 PM
stevenbaty's Avatar
i think the caster is off. i towed it without the steering locked. it went fine until i pulled out my neiborhood and it would turn back it stayed hard right. i made lovely sounds for about 200 feet before i gave up pulled over and locked the steering.
