Trailer tail lights?
Old Feb 18, 2006 | 09:05 PM
defenderjim's Avatar
Hello,
I have a small trailer (12 feet 1 7/8" class 2 ball) using the standard four pin wiring connector.
The tail lights in the back have a main light and a small wing light. What are the wing lights for? How do I get them to light?
The main lights respond to brake and left/right turn and front head lights turned on. But none of these actions cause a response by the small wing lights.
If you go here, this is what I have on the trailer.
http://shop.easternmarine.com/index....categoryID=207
Thank you for your help.
-J
Old Feb 18, 2006 | 11:55 PM
WildmanNP's Avatar
It's a side marker light,it may not be hooked up inside or the bulb is bad,it should come on when you have the lights on.
Old Feb 19, 2006 | 12:30 AM
Ok, interesting. The forward side marker lights do come on. I checked the bulb and they are fine. So, the wiring must be messed up in between.
Thanks for the info, now I know where to start.
-J
