Adding Trans Temp. Gauge ??
Old Nov 9, 2005 | 11:36 AM
sprint99's Avatar
Wanting to install a Transmission tempuature gauge in my 2004 5.4 Super Crew. Have anyone of You done this, and what do You recommend. Do these kits wire into the vehicles wiring (splice in) or is the sensor mount to the pan like older styles had a magnet onto the pan.
Thank You for any ideas.
Jeff
Old Nov 9, 2005 | 12:32 PM
Rich04F150's Avatar
I'd be interested in how to do this as welll.........
Old Nov 9, 2005 | 02:03 PM
MitchF150's Avatar
Not specific on the '04, but 'in general', you buy the gauge type of your choice (electric or mechanical) and the brand of your choice.
You will get the correct sensor with the gauge. Along with various adapters if you go the electric route.
You then put the sensor in either of several locations.... You can splice it into the trans output line, or the input line. Tap into the pan. Install into the test port on the trans itself...
Personnally, I installed mine on the trans output line up front and spliced into the rubber hose part of the line. I had to purchase additional hardware to make the splice, but I just picked it up from Home Depot in the plumbing dept....
Most go with the test port location however. You just unscrew a little plug, and temp sensor should thread right in. Tons of posts on the location and process for that procedure.
I mounted mine on the A piller in the cab. I got a dual one and also added a water temp gauge. If you have the driver side 'grab bar', then I don't know if a pod will work....
Mitch
Old Nov 9, 2005 | 03:23 PM
sprint99's Avatar
Thanks! Did some research online too, should be ready to do this soon.
Jeff
Old Nov 9, 2005 | 06:18 PM
ViperGrendal's Avatar
You can look in my gallery for a couple pics of mine. I put in the Autometer electric guage.
Old Nov 10, 2005 | 10:03 AM
Rich04F150's Avatar
Hey, Viper. Didn't see a link to your gallery?
Old Nov 11, 2005 | 12:28 AM
You can get to the galleries menu by clicking the "photo galleries" link at the upper right of the page, but, here's the link directly to it...
https://www.f150online.com/galleries....cfm?gnum=1299
Old Nov 12, 2005 | 02:52 PM
jims94vmx's Avatar
i also have one.....think you will like the pod i have for the guage.....click on my signature below to see pics. also search the archives, you will get alot of info there.....
