How much........
Old Oct 19, 2005 | 08:40 AM
lewis_ice's Avatar
Question How much........
weight put in the bed of my truck. I have to make a 350 mile trip nest month and want to know how much can I take that I don't want the moving company to touch?
I have a 2000 F150 xlt with a 6.5' bed.
thanks
Jason
Old Oct 19, 2005 | 09:48 AM
APT's Avatar
APT
2wd or 4wd?
Either way, your payload is around 1600-1700 pounds. That includes fuel, passengers, and cargo in the back. 200 pounds of gas and however much the people weigh gives you the rated cargo weight.
However, both of my F-150's haven't had any problems with a little extra weight. I've had 2500 pounds in the back of my Screw, plus 370lb of passengers for short distances. I wouldn't go 350 miles, though. Based on my two 4wd F-150's, I'd have no problem carrying 2000 pounds of cargo that distance if I had to.
Old Oct 26, 2005 | 08:16 PM
lewis_ice's Avatar
Cool It's 4wd...
...2000 XLT 4.6L. I have to drive 350 miles with about 1000 lbs in the bed and was wondering if I would have any problems.
Thanks for your help.
Jason
Old Oct 26, 2005 | 09:15 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Sounds like a full load for a Ranger but, not an F150.
The truck will steer easier than it ever has and that's about all you'll notice.
Old Oct 27, 2005 | 07:33 AM
APT's Avatar
APT
Yep, no problem for an F-150.
Old Oct 27, 2005 | 08:24 AM
kingfish51's Avatar
You should be okay. You will know it's there, and if you enjoy screaming around turns like I do, you won't be able to do that with the load. Just make sure you get it loaded right also. You will need most of the weight in front and over the rear axle. Don't have it loaded behind.
Old Oct 27, 2005 | 06:27 PM
lewis_ice's Avatar
Thumbs up You guys are great
Thanks for all your help. I really didn't want to get half-way through my trip and get in a bad situation.
Old Oct 27, 2005 | 08:54 PM
kingfish51's Avatar
One thing I forgot to mention. You will probably have to add air to your tires. If you have P series tires, probably to close to max. If LT tires, you won't need max, but definitely will have to bump them up a bit.
