Survey Help
Old Jan 27, 2004 | 12:21 PM
Turboed's Avatar
Survey Help
Hi everyone. I am a student at Purdue University, where I am involved in a trailer hitch project in a mechanical design class. If you could all please take a second to fill out this survey, it would help me out a lot.
Have you ever used a trailer hitch?
1. Yes
2. No
If No, thank you for your participation,
If Yes, please continue.
How often do you use your trailer hitch?
1. never
2. sometimes
3. often
4. frequently
5. daily
What type of hitch do you use most often?
1. Class I (0 - 2000 lbs)
2. Class II (2000 – 3500 lbs)
3. Class III (3500 – 5000 lbs)
4. Class IV (5000 - 10000 lbs)
5. Class V (10000+ lbs)
Check common problems with your hitch
1. difficulty aligning your hitch
2. excessive hitch wear/defects
3. rear tire wear
4. frequent/excessive changing of hitch ball
5. difficult initial set up of hitch
6. Other
___________________________
What do you most often tow with your hitch?
1. small trailer/bike
2. small motorized vechiles
3. boat
4. camper
5. oversized machinery
6. Other
What would you like to see in a new design? (Can be the hitch assembly, or an attachment)
_____________________________________________
How much would you pay for that design?
1. $30-$50
2. $50-$75
3. $75-$100
4. 100-$125
5. $125-$150
6. $150+
Old Jan 28, 2004 | 04:04 PM
messman24's Avatar
1. Yes
3. often
4. Class IV (5000 - 10000 lbs) would like to have just in case
6. Other Rust
3. boat
4. camper
6. Other (open 6x8 Trailer )
Stainless steel made so I would quit rusting..
5. $125-$150
6. $150+
2002 Ford 150 screw 5.4 4X4
Old Jan 28, 2004 | 04:25 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Re: Survey Help
1. Yes
2. sometimes
6. Other
No Problemo
3. boat
I would like to see you do the hook up instead of me.
1. $3-$5
(The easiest way to respond is to quote the orginal post then delete all the answers that do not apply.)
