`92 F150 , 3 values for trailer capacity?
Hello all! I have a `92 F150 , Ext. cab , 8` box with 3.55 LS , rebuilt E4OD trans , and 302cid. I have 5 leaf springs in the back , and hd coils in front.
My question is , In the owners manual , there are 3 different values for towing capacity , max. trailer weight. Which one do I go by
The first one with my config. says GCWR 8400 , trailer weight 0-2000# . The second one says GCWR 9,700 , trailer weight 2000 - 3500 #.
The 3rd one says GCWR 11,500 , trailer weight 3500 - 7700 #. I know GCWR is Gross combined weight rating , and the truck weighs in at around 4250 lbs with a full tank of gas.
The only thing I could come up with is the first value of 0-2000 #
Is common to all configurations. I am assuming this is a class 1 value , or towing off the bumper. The second value 2000 - 3500 #may be for a class 2 hitch , (frame mount) , and the 3rd value , 3500 - 7700 # Is for a frame / weight distributing hitch , a class 3-4 type.
Please help !!
Any and all replies greatly appreciated!
Sty
The first one with my config. says GCWR 8400 , trailer weight 0-2000# . The second one says GCWR 9,700 , trailer weight 2000 - 3500 #. The 3rd one says GCWR 11,500 , trailer weight 3500 - 7700 #. I know GCWR is Gross combined weight rating , and the truck weighs in at around 4250 lbs with a full tank of gas.
Please help !!
Sty
Hello. I am an autoworker, I build these things , and although you may think I should have immediate and instant access to any and all information about vehicles! Not true. The plant I work in right now , is focussed on building a quality product ( quality is job 1) and focus on the product we are delivering to you , the consumer. Because we are but one of many , anything I needed to know , I would ask an engineer. She (yes , she ) would know everything about the current vehicle specs. we are building now. If I need to know about an older or another product line , it would take time , bear in mind that the engineers have more to do to provide you , (us ) the consumer with a quality vehicle.
Now , back to my original question.
Please reply!
Sty
Please reply!
Sty
I think the door jamb label will only tell you the GVWR? At least that's all mine shows.
It looks like you are reading three different ratings for GCWR. There should only be one rating for your specific combo of engine, gears and tranny type.
The first two sound a bit low for GCWR with a V8, so they must be for the I6 motor?
My F150 has a GCWR of #12700 with the 5.4, 3.55, auto trans. I think it's #11500 with a 4.6, 3.55, auto.
