Which 5th wheel hitch?
Old Mar 12, 2003 | 08:45 AM
t_royotis's Avatar
Here's a question for you owners of shortbed Fords towing 5th wheels: Would you rate a sliding 5th wheel hitch a convenience or a necessity, keeping in mind that the trailer would have an extended pin box? I drive a '97 F-150 extended cab 4x4, 4.6, 3.55's, factory towing package. The wife and I are looking at buying our first (late 90's, used, 18'-20') 5th wheel. The majority of the short ones we're looking at come with extended pin boxes, and about 1/3 are offering the hitches as well. Would I be better off taking the "free" hitch (although I know I'll probably have to get rails and brackets), or setting myself up with a new sliding, or even fixed, hitch.
Thanks-
Todd
Old Mar 13, 2003 | 09:32 AM
George Eh's Avatar
I don't have the sliding hitch but my 1987 21' Prowler does have the extended hitch. So far I've never been in a position where I've needed one but I am careful when backing and always watch to make sure the trailer doesn't take out the back window. I also watch the distance between the bedrails and 5'ver as I only have about 5" of clearance. I could set the hitch higher but then the trailer would be way off level. I have a Hijacker hitch that is non-sliding but can buy the rails to make it slide if I wanted. Maybe the hitches they are offering you can also be converted to sliding. Enjoy the hunt for your trailer
Old Mar 13, 2003 | 12:12 PM
t_royotis's Avatar
Thanks George.
Where's the center of your hitch in relation to your axle: centered over the axle or slightly forward?
Old Mar 13, 2003 | 12:21 PM
IAmGeeky's Avatar
Where I park my 5er, the house is curbside and I have to back in from the right uphill. I use my slider at home and had to use it once in a year to back up a hill to a spot that is perched up un a little mound. I believe the slider to be necessary in my case. The 5er responds more quickly because it puts the pivot point further from the axle. I also believe there is less chance of impacting the bedrails.
I have read many at RV.NET forums that don’t have one and are just careful. Also some have stated tht they popped the rear window and damaged the cab. I can happen.
One thing, I think the further forward you put the hitch the better tow. Certainly above or forward of the rear axle. Using this idea, I would think being careful and using the slide could result in a better tow. Hope this helps.
Old Mar 13, 2003 | 07:51 PM
t_royotis's Avatar
Thanks to both of you (and Nash in the other thread) for your insight.
Iamgeeky: RV.NET is a great site I hadn't seen yet, thanks for the head-up on that one. I'll be spending a good amount of time there in the next few days.
Old Apr 1, 2003 | 10:22 PM
George Eh's Avatar
Sorry hadn't been to this site for awhile so I missed answering your post. My Hijacker hitch is 3/4" ahead of the axle as per their installation instructions. Reese puts their hitch 1.5" ahead of the axle, for detalis go to Hijacker and Reese. Hope its not too late
