Hooking tow rope to rear axle
Old Dec 21, 2002 | 07:08 PM
mg175150's Avatar
I recently purchased a 1999 F-150 4x4 without a tow package. I have not had a chance to add one yet. Today I was coming down the mountain when I noticed somebody stuck in the snow. I helped him out by pulling him back onto the road. Since I have no tow package or a hitch on the bumper, I had to hook the tow rope onto my rear axle. I pulled him out pretty lightly (no major jerking). Is there any damage that I could have done to my truck? Where is the best place to hook the tow rope until I can get a tow package? Thanks.
Old Dec 21, 2002 | 07:54 PM
SteveB's Avatar
I would have put the rope in the hole in bumper where the ball hitch goes.
Old Dec 21, 2002 | 08:12 PM
MitchF150's Avatar
Exclamation
Most tow straps have some sort of 'hook' on them. I would have attached it around the frame/bumper bracket at the very minimum.
At the worst, you could have ripped the axle from the leaf springs, but if that didn't happen, you are probably ok.
It's great that you helped the person out, but you should always attach a tow strap to the frame of both vehicles to avoid the possibility of 'bending' something.....
Old Jan 10, 2003 | 01:15 PM
Fast Gator's Avatar
check your brake lines that run across the rear axle
Old Jan 24, 2003 | 04:09 AM
JMC's Avatar
JMC
25 Year Member
Do you have front tow hooks? Next time attach the rope there. Better yet lose the rope and buy a strap and some shakels.
For info on "how to" check out;
http://www.geocities.com/~landroverp...ery_Straps.htm
For an idea of what gear is available check out;
http://www.recoverygear.com/DEFAULT1.HTM
Regards
Jean Marc Chartier
Old Jan 27, 2003 | 06:19 PM
RascalsF150's Avatar
You should never use tow ropes that have hooks attached to it to pull anyone out. Should it come loose, it will become a missle and will cause Death to anyone it hits. Buy a tow strap.
You should not connect to the axle, as you could pull it right off the truck. Always attache to the frame of the vehicle.
Buy 3 feet of heavy duty chain, a clevas ring and wrap the chain around the frame, then attach th etow strap to the clevas ring and attach to the chain, or buy some tow hooks and bolt (do not weld) them to your frame with grade 8 bolts. Hope this helps
Old Jan 27, 2003 | 07:15 PM
greencrew's Avatar
Since you were doing the pulling and not being pulled by the axle and there was no jerking you should be ok. Most snow pulls are low force pulls, and you don't have much traction to begin with. Good idea to check your break lines as suggested.
I would have gone with the fron tow hooks. If you have an XL then you may not have the tow hooks. I would put some on if it were my truck. The holes are there for tow hooks, you just don't have threads in the holes like an XLT has for the FORD stock tow hooks.
I use the front tow hooks most of the time. I just learned in this thread that using the hitch is better if the strap breaks. I'll remember that.
I picked up a Reese receiver tow hook (10,000#) that I'm look forward to pulling with. Also picked up a Highland 20' tow stap that's 2" wide and says it has a 20,000 lb break strength at SAM's. I don't know its working strength.
