Sig test
Old Mar 27, 2009 | 11:33 PM
CobyMedic's Avatar
Sig test
Nothing fancy but lets test it out.
Old Mar 27, 2009 | 11:36 PM
CobyMedic's Avatar
It worked
Old Mar 27, 2009 | 11:39 PM
ARCuhTEK's Avatar
Cool...way to go.
Old Mar 28, 2009 | 12:43 AM
ARCuhTEK's Avatar
I cannot get mine to work. I have done everything I know to go....I even know HTML coding! It shows up perfectly in my "edit signature" area under PREVIEW. It is the right size in pixels and dpi....it is on an imaging hosting site, linked back using the [SIG][/SIG] brackets....
sheesh.
Old Mar 28, 2009 | 12:52 AM
sheesh.
Are you clicking the box under the post window for the sig to show?
Old Mar 28, 2009 | 01:05 AM
ARCuhTEK's Avatar
The one that says show only one example per thread? Yes, I am. It should be set up to show in every one of my posts.
Old Mar 28, 2009 | 01:07 AM
No, do a post. Before you hit the submit button, look below it. Micelaneous Options, Show your signature
Old Mar 28, 2009 | 01:08 AM
ARCuhTEK's Avatar
Testing my sig too...
Old Mar 28, 2009 | 01:10 AM
There you go!
ARCuhTEK's Avatar
Well it works. But only for one post? I cannot imagine that I am required to remember to click that box every time I post?
Old Mar 28, 2009 | 01:14 AM
Yep, afraid so. It's a habit that is hard to break, once you start. Some people don't think you should show a sig but once each thread.
If you use the quick post feature, you can check the box at the bottom for your sig to show on each quick post.
Old Mar 28, 2009 | 01:18 AM
ARCuhTEK's Avatar
Ahh I see...the quick post check box!! Hail to the quick post!
Old Mar 28, 2009 | 05:14 PM
CobyMedic's Avatar
ARHuhTek
Nice sig, what did you use to create it?
Old Mar 28, 2009 | 05:19 PM
ARCuhTEK's Avatar
Originally Posted by CobyMedic
ARHuhTek
You can use photoshop, but I am a long time fan of Corel products. I used CorelDRAW and CorelPHOTOPAINT to create my sig.
Here is a thread over in DIYMA forum, where I give a tutorial on other kinds of graphics, many of which are basically the same ones used to make this sig.
http://www.diymobileaudio.com/forum/...m-diagram.html
Old Mar 29, 2009 | 11:09 AM
CobyMedic's Avatar
Wow, thats a pretty impressive right up. I am sure alot of ppl here would be interested in reading that.
