Sponsored by: CARiD
anyone tried add-a-leafs
Old Nov 20, 2002 | 12:12 AM
quadracer's Avatar
has anyone tried a 3 in body lift with torsion bars cranked about 1.5 inches in the front . and should i get blocks, shackles,or add-a-leafs for the rear and if possible were and what kind?
what size tire 305 or 315?
thankyou
Old Nov 20, 2002 | 06:57 PM
Scott D's Avatar
I just put a 1.5" add-a-leaf on. It was ProComp brand from 4wheelparts.com. Once you get the springs off it was pretty easy to install (you'll need C-clamp to keep the springs together when you remove the center bolt). They came with a new center bolt (had to trim it) and new bands.
It does stiffen the ride a bit but looks and fits well (you get a bit more load capacity too).
These come with the Procomp 2wd lift kit so there are a few threads to read about it here.
No complaints............Scott
Old Nov 22, 2002 | 09:55 PM
JMTruck's Avatar
I cranked my truck torsions about that height. I added 3" blocks to the rear. I suggest to visit my website so you can get an idea.
Old Nov 23, 2002 | 04:13 AM
mulder149's Avatar
I also added an add-a-leaf with torsion crank, I got 2 inches and got the add-a-leaf from 4wheel parts also, $42.00 after tax.
and easy to install. good luck.
Nate
