Sponsored by: CARiD
Which Lift Should I get??
Old Nov 15, 2002 | 11:12 PM
sdf150guy's Avatar
I am looking into the Fabtech Spindle lift, RCD 6" lift and the Rancho I believe its a 4" lift, I dont like the spindle lift because I dont think it is high enough, but it does look good, which lift would be the best to run 35's and look good and not cramed. I have 3.55ls and would be getting 4.10's to run the tires on. Im looking into lots of options for the truck so any suggestions would be great!!!!!
also one more question, if I get different rims and tires, how off is the spedo?? Will the governer do anything wierd like if im really going 75 and it says 95 will it kick in?? Or is it just better to get it re-programed, and how much does that cost??
Old Nov 16, 2002 | 05:28 PM
woodster's Avatar
i have the RCD 6 inch lift with 35's and it rides great. Ihad to trim the plastic under thefront bumper to run 35's. I would recommend that lift to you .Also the speedo reads slower than u are really going. so if your speedo says 65 your really doing more like 72-73 mph with 35 inch tires. Im sure 33's would prob be close to the same...goodluck
Old Nov 16, 2002 | 05:35 PM
sdf150guy's Avatar
what gears are you running??
