Sponsored by: CARiD
F-150 Lube points?
Old Nov 10, 2002 | 12:37 PM
bhost's Avatar
Question F-150 Lube points?
Can anyone tell me how many grease zerks there should be on my 2001 F-150, as well as where to look for them (dang bi-focals aren't worth a squirt when lying on my back)? I've only been able to find two (on the ball joints I think) even though the owner's manual seems to insinuate more, including on the steering mechanism.
Thanks. :o
Old Nov 10, 2002 | 01:33 PM
AjRagno's Avatar
I'm going to guess that there is only 1... perhaps 2. I'm pretty darn sure that ball joints are lubed for life though.
My 1997 4x2 only has a grease fitting on the idler arm. I also have 80,000 miles and need to replace every single steering linkage. I guess it's the potholes more than lack of lubrication though
Old Nov 10, 2002 | 07:06 PM
blk'02's Avatar
My 2002 only has 2.
Old Nov 10, 2002 | 11:22 PM
FamilyRide's Avatar
My Expy has 2 as well. The Idler Arm.
I just bought a needle for my grease gun (Auto parts store for about $3) and injected all of the boots that were collapsed. Just doesn't seem right not to have a little fresh grease in there.
Old Nov 11, 2002 | 03:25 PM
MANDRAKE27's Avatar
I guess Ford didn't want to shell out the extra $0.04 for a couple more zerks. My 97 only has two fittings. I also just greased the boots, especially the one above and below the end of the pitman arm. It was making an embarrassing squeal every time I turned the steering wheel. There has been alot of talk on here about the pitman squeal, but I imagine its bound to occur everywhere eventually. Invest in the needle for your grease gun. I just did and its well worth the $2.95 Hope this helps CIAO!
Old Nov 11, 2002 | 07:04 PM
bhost's Avatar
Thanks everyone. After I posted my query I found a couple other threads that addressed pretty much the same thing, with the same responses. I guess when the ball joints go bad I'll just replace them with aftermarket parts that DO have zerks!
Old Nov 11, 2002 | 07:08 PM
Thad's Avatar
Can anyone tell me where you put the needle? Do you just punch a hole in the boot or do you work it in on the edge of the boot? Thanks.
Old Nov 12, 2002 | 03:55 AM
MANDRAKE27's Avatar
Hey Thad.....Here's what I did on the advice of many in here. I just bought a little needle that screws onto the grease gun, and a tube of silicone sealer (much like that blue gasket stuff) Then I cleaned the rubber with a little solvent, and wiped it with water, and dried it. I poked the needle right in the middle of the clean spot and pumped it with grease until it felt firm, but not ready to explode. Then just smeared a dab of silicone over the hole. So far so good, and that was about 15000kms ago..Hope this helps!
Old Nov 12, 2002 | 11:57 AM
Thad's Avatar
That helps alot, thanks. I bought the needle today but had not thought to reseal the hole. Great idea.
