Sponsored by: CARiD
balljoints? will the be covered if....
Old Nov 8, 2002 | 09:22 AM
Mike5959's Avatar
I have a 2002 4x2 with a belltech 3/4"drop. will ford warranty the ball joints? I hear a lot of popping in my driver's side when turing and hitting bumps.
Old Nov 9, 2002 | 08:31 PM
offroadmaniac's Avatar
I dont think that ford will cover your ball joints, especially since you put the drop on there. But, why should you be worried about ball joints already?? They shouldnt need to be replaced.
Old Nov 10, 2002 | 12:06 AM
TexfordD's Avatar
i'd look at you're tie rods and...
make sure they're not binding at full rotation
Old Nov 10, 2002 | 04:49 PM
ROUSHFAN-1's Avatar
WOW .!!!!! what are you doing over here?...WORLDY...hehh hehh......what's up Mike..could be the pitman rub problem ..all you need is a little grease...
Old Nov 10, 2002 | 05:10 PM
Mike5959's Avatar
Hey, whats happenin? I havent seen you over at the world since I met you guys on the berlin tpk. Your trucks still looking good! I managed to throw some 20s on and a 3/4" drop since then. I also installed a ps2 and a 7" monitor and a 5"in the visor. I also have the bed rug, xlt front valance with fogs., and I Am sure I am missing a million other things.
thanks for the info on the pitman.
Old Nov 10, 2002 | 05:18 PM
ROUSHFAN-1's Avatar
yeah i saw pics over there ..truck is looking really good !!!..did a little shopping over the summer huh ?
Old Nov 11, 2002 | 08:54 AM
APT's Avatar
APT
Ford just covered the ball joints and wheel hubs on my 99 4x4 under the ESP, but it is not lowered.
Old Nov 11, 2002 | 01:04 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
Silly question, but did you use lower bumpstops and lowering shocks? I know I know,,,,98
Old Nov 11, 2002 | 01:23 PM
Mike5959's Avatar
I used the belltech nitro drop shocks(they really suck) and I did not change the bumpstops on the front. I was going to trim them but I dont really haev any issues with hitting them up front. I hit the rears alot but those are the ones that came with the kit. These shocks just arent made for a truck this big., they must work ok on minis.
Old Nov 11, 2002 | 04:38 PM
ROUSHFAN-1's Avatar
I would check those bump stops again...once your springs settle in they will hit...i installed short ones with my Roush kit and the definatly hit !
Old Nov 11, 2002 | 04:43 PM
Mike5959's Avatar
ROUSHFAN1 what are you using for a drop? I forget what you had said.
Should i cut mine or just get some?
