Sponsored by: CARiD
fabtech 6" inch price plz
Old May 6, 2002 | 09:31 AM
hmiz's Avatar
Fabtech 6" liftkit what the price on the kit.and how did u do the rear with block or was it a added leaf spring. and if so how did level (even). any feedback will be help full. I been quoted for rcd 5" lift for $1499.00. but they say it will set 4"inch on fords 4x4. so I think fabtech true 6" inch lift will be better. can you tell me how it rides any big different from stock and how much different in gas mileage .
https://www.f150online.com/galleries...y.cfm?gnum=394
Old May 6, 2002 | 03:07 PM
TeamTrent's Avatar
I think I paid about 1359.00 for my kit. It is a "true" 6" kit. Ride quality is better than stock and is the way a 4x4 should ride. The rear is a block but Fabtech offers a leaf if you like. As for how the truck sits, it is level. I have taken the truck off road many times and the kit is holding up well. No loose parts. I'm running 35" tires on mine, but as far as MPG......... it depends on your gear. I would recommend doing gears as well. If you want height and don't want to lift the body like me, then I would go with this kit. Do your research to see what kit works the best for you though Good luck. If you need more info or pics then drop me a line.
Old May 13, 2002 | 07:24 PM
heywood475's Avatar
I bought mine for $2200 installed at 4wheelparts, i also got 4.56 gears and a rear locker. Gears make a huge diff with the bigger
tires.
Old May 14, 2002 | 01:32 AM
Rhyno's Avatar
Heywood what kind of rear locker did you get and what size rear diff do you have?
Old May 14, 2002 | 07:41 PM
JMTruck's Avatar
Question
TeamTrent, how tall is the rear block?
Thanks in advance for the info.
Old May 14, 2002 | 10:43 PM
TeamTrent's Avatar
2" plus they use the factory block. Don't worry the truck will sit level.
Old May 15, 2002 | 04:17 PM
JMTruck's Avatar
Thumbs up
Thank you.
Old May 18, 2002 | 10:20 AM
heywood475's Avatar
4.56 gears
