Sponsored by: CARiD
Leaf springs
Old Mar 7, 2002 | 01:03 PM
kpaton's Avatar
Question Leaf springs
I have yet to check this out on another F-150 but I noticed this today. The bottom leaf is out of alignment with the upper leafs and there is a gap between the bottom and the next one with a plastic spacer and a pin, the gap is only at the last few inches.
Is this gap normal or should they be tight together? I have 70,000 mi on the truck and didn't know if I should have a shop look at this.
Thanks in advance for your help.
Old Mar 10, 2002 | 04:33 AM
36racin's Avatar
KPATON,
THERE WAS A TSB ON THE MISALIGNMENT OF THE REAR LEAF SPRINGS SOME TIME AGO. I HAD THEM CHANGED ON MY TRUCK BECAUSE THEY KEPT SEPERATING FROM EACH OTHER. THE BULLETIN SAID THERE WAS A POSSIBILITY THAT THE SPRING COULD POSSIBLY PUNCTURE THE GAS TANK IN SOME CASES OR THE LEAF WOULD BREAK OFF. MY TRUCK GOT THE UPGRADED ONES AND I HAVENT HAD ANY TROUBLE SINCE.
Old Mar 10, 2002 | 06:35 PM
J-150's Avatar
I read about this recall as well. It only applied to 4x4's, not 2wd suspensions.
Old Mar 12, 2002 | 07:41 PM
poo_'s Avatar
Question 36racin???
how'd u get them to put new leaf's on your truck? did u just pull into a dealer and say i want new leaf's or what? my leafs are crooked as well...please reply thanx
Old Mar 13, 2002 | 08:46 AM
hog's Avatar
hog
i also have this problem. but my truck is no longer under warrenty, will ford charge me to fix this problem?
Old Mar 14, 2002 | 01:52 AM
big4x4's Avatar
I had the same problem with mine, and Ford replaced them.
Old Mar 14, 2002 | 01:20 PM
kpaton's Avatar
Sorry I have not been back to this thread in a while.
I looked into the recall and this does not include my truck because I have the off road package.
Is there anyone out there that had them replaced/fixed on a truck with the off road package and 4x4? Does anyone know if this is even an issue? I do not know what they are supposed to look like.
There are straps holding the top three together.
Thanks for all your responses.
