Sponsored by: CARiD
better handling mods 101
Old Jan 16, 2002 | 07:06 PM
LBC150's Avatar
hey guys,
my truck rolls A LOT. nothing out of the ordinary as far as trucks go...but i am looking to eliminate a good deal of body roll. and i would like to stiffen up the ride a little bit. Make her handle a good deal better. what would you guys say is the most cost effective way of doing so? what mods do you have and how are they working out? (see sig for infor on my truck)
A
Old Jan 16, 2002 | 07:14 PM
ChaoticRacer's Avatar
The usual. Better, stiffer shocks, higher rated sway bars, urathane bushings, better tires than the stock ***** ford gives ya
Old Jan 16, 2002 | 10:14 PM
LBC150's Avatar
Unhappy
ChaoticRacer,
i was thinking about the swaybars but was concerned about a couple things. anyone who can answere these for me would be appreciated.
1) i might drop my truck in the future...something small...two inches maybe. do i have to get a different sway bar? i ask this because i saw sway bars for trucks with 3 inch drops. is there a certain amount of "dropping" that requires a new one?
2) this is not really a concern, but how much do these wiegh in comparison?
Old Jan 16, 2002 | 11:23 PM
Corpsie's Avatar
1. a 2" drop shouldn't require you to get a new sway bar (if you get a new one now)
2. the weight is very insigficant.
Old Jan 17, 2002 | 12:54 PM
streetcrusier's Avatar
You can just modify the end links to be shorter or just buy shorter end-links if you drop your truck. Sway bars make a huge difference.
Later
Old Jan 17, 2002 | 09:36 PM
David Anderson's Avatar
Speaking of better sway bars - does anyone know if some one makes a front sway bar for the 4x4s? Hellwig doesn't make one, they claimed it was to hard to install!!!! I find this hard to believe when all every one talks about is body lifts and suspension lifts and drops, much harder than any sway bar to install.
Do they still offer the 1 7/16 sway for the 4x2s? I don't know if there is enought clearance around the frame to use this one on the 4x4.
Does Ford offer a heavier version for he Lighting?
Old Jan 17, 2002 | 11:23 PM
dirt bike dave's Avatar
The Edelbrock shocks alone greatly reduce body roll. I was really surpised how much. Essentially, when the wheel moves upward slowly like during cornering, they are much stiffer than stock, but when the wheel moves fast like in a pothole, the shock moves quickly to absorb the bump.
I've added a rear sway bar, a 2" rear drop, & front urethane bushings, and the shocks made the biggest difference. From experience with other vehicles, I would say some good tires would probably make the biggest difference of all.
Old Jan 18, 2002 | 11:01 AM
max mitchell's Avatar
I tried adjustable shocks, wider HP tires, and a front and rear anti-swaybar. I did each one separate then evaluated them for a few weeks. They all helped; I'd do each one over again and recommend it, but by FAR the most noticeable was the front bar.
