Sponsored by: CARiD
BelTech 2-4 drop?
Old Oct 7, 2001 | 07:49 PM
F1504u2nv's Avatar
BelTech 2-4 drop?
I recently purchased a 2-4 drop kit from Beltech for my 99 F150. I put the springs in so the front is done and ive previously done 2 inch drop shackles in the back. My question is the hanger. It says take a cutoff wheel and cut a slot in the head of the rivets then take an air chisle and knock off the head and pound the remaining shaft through. I just ended up grinding the head of a rivet into nothing and it sort of just melded in with the hanger. Has anyone put hangers on their truck or did everyone who did a 4 inch drop in the back have to take it to a shop cause that looks like what im gonig to have to do.
Old Oct 7, 2001 | 11:34 PM
99flareside's Avatar
I just had a shop install my Belltech 3/4 drop. I didn't want the hassles or end up ruining something. I have read that after grinding off the rivets they heated the remaining part and then punched it out with a hammer. Hope this helps some.
Old Oct 7, 2001 | 11:46 PM
F1504u2nv's Avatar
Yea it helped a little, but if you dont mind me asking how much did they charge you for the install?
Old Oct 8, 2001 | 01:37 AM
They charged me $350.
Old Oct 12, 2001 | 12:35 AM
fastv6's Avatar
Thumbs up
poorboys performance did my drop and they were cusing when they were done with the rear . the rivets wouldn't come for nothing .... they blew a hole through the rivet with a torch and beat the rivet out with an air hammer .... better them than me
Old Oct 13, 2001 | 01:07 AM
NOSTROMO
Guest
Posts: n/a
The easiest and safest thing to do is use an air powered cutting wheel or similar. Notch an X on the rivet and hammer the head off. Lastly, push the rest of the rivet out with a punch and hammer. Using a torch is not the best idea on the frame....
Anthony
Old Oct 15, 2001 | 03:52 AM
BroncoAZ's Avatar
When doing the lift kit on my Bronco, I ground the heads off the rivets and punched them out with a 3 pound sledge. There were about a dozen of them to grind off, it wasn't much fun. The F-150 looks much easier than that project was. I don't know if I'll ever lower mine or not. Hell, I'm still tempted to put a 3" spindle lift on it...
Good Luck,
Mitch
