Sponsored by: CARiD
2021 F150 Lariat
Old Dec 13, 2020 | 12:30 PM
Irishfireman07's Avatar
2021 F150 Lariat
Looking at ordering a 21 Lariat F150 SuperCrew 3.0L PS. Want to level it. I know on my 3/4-ton it was recommended to replace my track bar if I leveled 2". Is the same required on the 1/2-ton? RoughCountry doesn't have an adjustable track bar for the F150 so is it just a drop bracket I need to find? Also, is there much difference between the leveling strut kit and the leveling strut extension spacer kit?
Old Dec 29, 2020 | 10:01 PM
limoman39's Avatar
By track bar, do you mean the sway bar? If so you shouldn't need an extension. It will be fine... Word of advice, make sure you read the forums about tire size & lift. I did a 3" leveling kit with 35" tires and hava a lot of rub. I am now dealing with other issues like cv boots splitting and iwe hubs not working. Will probably replace my leveling kit with a 4" lift kit from RC. Went with the leveling kit to save some dough but am going to end up spending more to make it right.
Good luck with the new truck...
Rick
