Bilstein 5100 questions
Ok, so I have a 2015 F150 2wd. I purchased a set of 5100's for the front suspension only. What height setting should it be set at so that I can fit 34/35" tires all around?
No idea, but I set mine at the 1.5" setting, which was one ring less than the max and I only have the stock tires, so I don't think even going to the max setting will do much for those size tires??
But, I can say I do like the 5100 Bilstein shocks. I also did the rears, so I have them on all 4 corners and it's a lot better than the stock shocks for sure! I've got a 13 F150, so probably a bit different from the 15, but I like 'em..
And just the rears for reference..
Mitch
Mitch
