Noise in front end
Ok this problem has been bugging me for 3 weeks. In fact i have used up my entire vocabulary of swear words.
When i am driving i get a metallic ringling, jingling type noise from my right front tire. It starts at about 30 miles an hour. All my lugnuts are tight, my centercap is tight. I originally thought it was the metal shield behind the rotor so i removed it. The noise is still there. I found that the lower nut on the coil spring was loose causing the washer to move around so i tightened it but it still did not solve the problem. I even checked the catalytic converter heat shield even though it's on the other side of the truck. What is making this noise?
It doesn't bother me since i can't hear it with the radio on anyways but people give me strange looks when i drive by.
-Jon
-Jon
