time to upgrade
have a 2008 F150 4X4, about to reach 50K miles and would like to change out the shock absorbers before I replace my tires(going with LT 285/65 18 load range E BFG AT KO2), truck is completely stock.....any suggestions
sincerely and thanks
I'm in the exact situation with my 05.
37,000 miles, and the factory tires need to be replaced.
I have been planning on getting the Fox 2.0 leveling struts when they come on sale again. (about this time last year, I think)
I plan on getting 275/70 R18 BFG AT KO2 tires.
Check out the Bilstein 5100's...you can use them at stock height or set them to level the truck up to 2 inches. They firm up the ride and should work well with the E rated BFG's. Front and rear shocks usually run about $350 to 400 bucks not counting install.
