Sponsored by: CARiD
looking for leveling kit
Old Jan 9, 2015 | 12:08 AM
F150medic's Avatar
looking for a leveling kit for a 2000 f 150 2 wheel drive I also need to know if i am going to need one for the rear as well thanks please include links
Old Jan 16, 2015 | 12:46 PM
wandell's Avatar
Daystar makes coilspring spacers for the front of your truck. Fabtech and Pro Comp used to make lift springs for your truck also. If I remember correctly, 2 or 2.5 is the limit that you can raise the front without adding longer upper control arms. It would also be a good idea to install adjustable camber bolts since they are inexpensive and some trucks (not all) need them to get the alignment within specs. If you want the truck to sit level you probably won't need to lift the rear any.
Old Jan 16, 2015 | 02:42 PM
pizzaman711's Avatar
The 97-03's need around 1.5-2.5" to get level, it's dependent on the truck and how worn the factory coil and leaf springs are. Your best bet is to measure it from the center of the wheel to the top of the fender opening on both sides, average them together, and then find the difference between the front and the back.
Anything over 2" will require longer aftermarket control arms however.
