Sponsored by: CARiD
TOPFIRE“Elegant Devil”-FORD F150 Raptor
Old Nov 15, 2014 | 12:56 AM
Topfire's Avatar
As the derivation of F150 PICK UP, which is the best sale type under Ford, Raptor take the characteristic of American motoring --- rough and tough --- highlight unique of hardstyle. The original package of Raptor , like 6.2L V8 Engine plus a six-speed transmission, has enough attraction to fire everyone. However, in TOPFIRE, it is just a beginning. For recovering series of defects of Raptor modification in the past, this time TOPFIRE has customized exclusive modify plan: hanging and lifting reinforcement; all-around fender-guard and lights upgrade; car outside inkjet; “Hunter” version interior upgrade for drive ****pit; and Mechanical pressurization components with over 600+ horse-power.
TOPFIRE 8 inch hanging components use precision and strong differential holder, drop off differential reasonably by considering all-sided design and using car original positioning element, which shows simple and strong. Not only hanging head of car, but also keeping the angle of axle shafts in optimum state to avoid damage and danger from over included angle of rotational system.
The I’CON upper control arm, which is monolith cleaned by high strength aviation aluminum, is our necessary part of modify super Raptor. Because it is not only very strong , but also with wide adjust space that can position front tire accurately after car hanging. KING is always our only choice for shock absorber. TOPFIRE 8inch hanging components with 3.0 pipe diameter TEIN and Tri-Channel for front; and for back part , installed two 2.0 pipe diameter soft and hard double spring outer nitrogen tank shock absorber. They reduces motoring shock no matter facing high-speed turn, problematic roads, or long-distance drive. In addition, they can control the incline when car make a turn, and also because it can keep toughness to avoid heaving tossing. The Double shock absorber system enhance they work in best condition to long-time provide comfortable driving feeling to drivers. For assistant with KING back Nitrogen gas damping, which protect shock absorber to avoid compressing when heave load and car touchdown, extend the product lift. TOPFIRE add a couple of bracket support arm in package to install between each holder of transmission and differential to build a stable triangle holder. Besides, 38 inch Mickey Thompson MTZ tires assistant with - 44 20 inch double color two-piece wheel hub, brings amazing performance and prefect visual effects.
In the case we are talking about customization, appearance part of course we chose to using TOPFIRE products. TOPFIRE wide-body suite is absolutely necessary. It can reduce car damage from silt, also the streamlined design reduce coefficient of drag and upgrade hanging travel space, makes car and big tire looks more harmonious.
TOPFIRE MARAUDER series front bumper with huge approach angle provide strong passage capacity to car. The diamond- cut design perfectly fit car body line, and also looks clean and angular. Built-In over to 18500 pound of winch inside of bumper to make sure the ability of super Raptor to rescue self and others. Made from high strength carbon steel and fine welding makes TOPFIRE MARAUDER full of industrial male element. The 30 inch double row combined LED, 6 inch single row and embedded 2 inch senecio ambraceus are standard configurations of TOPFIRE MARAUDER. They ensure all-weather sight of super Raptor.
For back of Raptor, we also chose TOPFIRE MARAUDER series back bumper for echoing design, appearance and clean-line of front bumper. Besides, the strong spare wheel carrier holding 38 inch wheel in the back of car, looks full of stereoscopic.
Super light aluminum luggage box is also one of the necessary accessories, which can storage each luggage to save space inside of car. Two sets of two-row LED spotlight that installed in front of luggage box provide remote lighting support.
The unique car sticker belongs to TOPFIRE ASURA’S WRATH series. They are bold, unconstrained, and are the symbol super Raptor. They are always focus nowhere you go.
TOPFIRE strongly not accept the original simple and stupid interior of Raptor. Although outside looks like a devil, inside should be elegant. So TOPFIRE design team design and customize first “Hunter” version interior upgrade for this super Raptor, by splicing calfskin leather that processed by different craft, which broke prim line and highlight TOPFIRE “be yourself” principle and attitude.
411 horsepower and a 9-second 0-to-60 time of 6.2 V8 engine now cannot satisfied customer’s requirement of power, also cannot let super Raptor run widely. Finally we choose PROCHARGER supercharger made in the USA.
PROCHARGER included following accessories: big size turbine with ventilation and heat dissipation oil pump, huge Inter Cooler which can reduce temperature to 30 degree, SCT computer for upgrading system, high quantity Injection Nozzle, and all-size pipe and holder. This time Technical Director of TOPFIRE debugging SCT computer by himself instead of simple installing hardware and system. We used more powerful SCT computer to survey entire car system. Adjust mechanical supercharging system to best condition focus on characteristic of Chinese fuel and car using environment, which increase horse power to 600 + safely and a 6-second 0-to-60 time ! After computer system debugging well, every data is adjusted suitable, then input to computer and start the engine. The whole thing successful in one time – no interference, no high temperature, no strange noise , SCT computer be checked well, no any fault code --- very controlling system and sensor works well with nice growl of a big turbine.
Of course cannot let such a wild Raptor be a monster out of control. Top brake of BREMBO made in Italia (Six in front and Four at back) and 380mm crossed slot and punching brake sets provide top security and safe to this super Raptor. Multiple piston calipers are made from one iron forging and 5 times stronger than caliper made from traditional forging way. Each piston is pushed by braking fluid to ensure braking power. And the crossed slot can avoid rolling friction from dust and increase the friction between brake disc and brake block. Punching hole increase wind blow speed of brake disc and cooling efficiency. The thermal decay is reduced efficiently and avoid heat transfer form rim to wheel, which minimize the risk of flat tire by high temperature.
Double shock absorber system co-operate with 8 inch hanging, plus 600 + horse power engine that upgraded by pressurization system, here born the first super Raptor in China!
This is TOPFIRE, we are making “Elegant Devil”!
