Sponsored by: CARiD
can someone post pics of a09+ 6 inch lift with 33s
Old Oct 16, 2014 | 09:52 PM
muddyfx4's Avatar
Hey everyone, im saving up for a 6 inch lift but my tires are really new and would like to wear them out before I buy bigger ones. Anyone have a pic?
Old Oct 16, 2014 | 11:55 PM
Actual dimensions of the tires? And AT or MT? If they're 295mm wide and MTs, I say go for it and it'll look fine. I can get pics of an 04-08 with 33" narrow muds.
Biggest problem I'm seeing, using info from your sig, is that your wheels may have too much backspacing to use with a lift other than a Rancho. Most call for a MAX BS of 5"
Old Oct 17, 2014 | 12:59 PM
jrowe191's Avatar
It's not an 09 but it can give you an idea of what you're looking at.
Also i have a Zone 6" lift, which online actually says my wheels wouldn't work with the lift is wrong. I my monsters are +18 and 5.71 backspacing as well. I easily cleared these 33's, and just recently put 35x12.50x18 trail grapplers and still have room to play.
Old Oct 17, 2014 | 01:21 PM
^ You don't rub on the spindles? That's the only reason they suggest wheels with lower BS, not for clearance issues.
Old Oct 17, 2014 | 02:28 PM
muddyfx4's Avatar
I have 33x12.50x18s nitto mud grapplers. No rubbing of any kind. Saw a truck with this backspacing and rim size with a procomp 6 inch lift. Looks really bad ****.
Old Oct 17, 2014 | 02:36 PM
muddyfx4's Avatar
https://www.customwheeloffset.com/wh...-6-custom-rims
Old Oct 17, 2014 | 02:44 PM
jrowe191's Avatar
No rubbing there. And here with the 35s i still have about an inch or more of space before rubbing anywhere.
Old Oct 17, 2014 | 05:58 PM
muddyfx4's Avatar
Man your truck looks nice. Makes me regret getting rid of my 06
Old Oct 17, 2014 | 07:27 PM
With 12.5" wide Mud Grapps, I'd get the lift without hesitation.
However, again, the wheels are an issue with rubbing on the lift's new spindles. Jrowe's tires, while 35s, are only 295mm wide (yours are 325+).
Old Oct 18, 2014 | 01:47 AM
jrowe191's Avatar
Thanks. It's a work in progress that's for sure. Bumpers need replaced, wanting a bull bar and LED light bars. Wouldn't mind fender flares. Just need about 3 more jobs and i'll be set haha
