Sponsored by: CARiD
Where to measure for leveling?
Old Aug 5, 2014 | 07:16 PM
Gramps's Avatar
Did a search using "measure" as search parameter. Came back with way too many threads. Where is a reliable place to measure to determine leveling requirements?
Old Aug 6, 2014 | 10:51 AM
EsJayEs's Avatar
Measure from the lip of the wheel to the fender on all four corners with the vehicle on a level surface and ideally a 1/2 tank of fuel. There will be a little variance, so take the average of the rear and the average of the front to determine the difference.
If you're a little in-between, err on the side of caution and go smaller. The higher the nose sits compared to the rear, the worse the steering will feel.
Old Aug 7, 2014 | 09:21 AM
maxpat82's Avatar
lip of the wheel, center of the wheel or ground is about the same
Old Aug 8, 2014 | 06:04 PM
Gramps's Avatar
Thanx for replies.
