ONE INCH LEVEL KIT 2010 4x4 Screw questions
I have an F150 4x4 super crew with 5'5" bed. I want to level it but my problem, which seems to be a litttle different than others is, It is only 1.25" out from being level. I see where lots of folks say a 2" kit wont get you level. Not in my case. Anything higher than 1-1/4" will make me nose high. How much actual lift will the one inch lift give me? Ive heard the one inch is actually a one inch puck, resulting in 1.5", which is the same as the autospring 1.5". Can anyone give me some specific input on how to go? I dont want to add a rear block.
How did you measure
If you try to measure from the ground you may come out a bit off due to the including the tire tread and air pressure differences.
