Point me in the right direction please
Hey guys I am expecting delivery of my new 2014 Screw Lariat any day now and think I want to put a small lift/leveling kit on this one. Nothing high or extreme just like the look of allot of the trucks i have seen here that have nice big 20" wheels with BFG tires.
I guess what I am looking for is where and what and who to buy from and what I am looking at price wise ?
Depends. If you go the less expensive route (level kit/spacer), Autospring is generally who is recommended. Either a 1.5" or 2" will look good and clear bigger tires. If you just level the front, you're looking at $85 for the spacer itself. You could also do what I did and add a 3" rear block to a 2" spacer up front to keep close to the factory rake. I believe that's an extra $130 or so.
The other, more expensive route is to go with adjustable shocks like Bilstein's, Rancho Quicklift, or Icon's. This will run you anywhere from $300 or $400 (just doing the front) to almost $2,000 (with the Icon setup).
The adjustable shocks will give you an improved ride, even with bigger tires. The spacer won't hurt your ride, but bigger tires will.
Edit to add: Stage3 has a pretty good line up for you to compare prices here: http://www.stage3motorsports.com/201...ling-Kits.html
Or their lift kits: http://www.stage3motorsports.com/200...Lift-Kits.html
