Sponsored by: CARiD
lowering kit issues
Old Jan 11, 2014 | 12:15 AM
ALLULC's Avatar
lowering kit issues
So im trying to decide if im going to lower my 2011 fx2 the 2/4 or 3/5. I have had a lowered truck 2006 chevy silv. (3/5) before and when I put my 4wheeler in the back and hit any kind of bump I was banging the bump stops.*
My question is whats the deal with the pinion angle? I havent ever messed with any of that neither do I want to.*If I did either of these do you guys just trim the bump stop or buy a replacement?
Old Jan 11, 2014 | 12:46 AM
helper bags.
as for the pinion angle, do you have a 2pc driveshaft? What kit are you using in the rear?
Old Jan 11, 2014 | 01:22 AM
ALLULC's Avatar
Idk if its 2pc or not.
I havent bought the lowering kit im just trying to decide which one I want
Old Jan 11, 2014 | 01:31 AM
two piece you do carrier relocation. one piece you shim the trans up higher
Old Jan 11, 2014 | 09:30 PM
ALLULC's Avatar
Is doing either very hard? Is it something the install instructions will walk you thru?
Old Jan 17, 2014 | 01:56 PM
maxpat82's Avatar
the hardest it the carrier kit which need to cut and redrill the mount on the crossmember.
You're able to do it with a grinder and zip-cut disk.
I did mine on simple jack stand.
