Expedition Lift Question
Long time reader about F-150's but new to the site as a member. I've been wanting to do something different around this town of mine, I don't see many lifted suvs; actually none that is a ford expedition. Its a 2004 EB edition Expedition 2wd (I read the 4wd is no different in regards to suspension and stock height). The kit I found is on ebay. It is 3.5" in the front and 2.5" in the rear. So, if I put the strut spacer in there, will I need new, longer shocks or will the factory be good enough? I know its not an F-150 question but this is the best site; I have gained a lot of info on here in past. Thanks.
Here is a link to the level/lift kits; which is better nylon or carbon steel?
nylon: http://www.ebay.com/itm/LIFT-KIT-NYLON-B-FRONT-3-5-REAR-2-5-EXPEDITION-03-11-2WD-4WD-/130948743227?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AExpedition&hash=item1e7d27403b&vxp=mtr
Carbon steel: http://www.ebay.com/itm/Carbon-Steel-Coil-Spacer-Lift-Kit-Front-3-5-Rear-2-5-4X2-2WD-4X4-4WD-/261311353907?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AExpedition&hash=item3cd75ed433&vxp=mtr
First, 3.5 inches of lift is way, way too much lift for just a spacer. The CV joints will be at too severe of an angle to last. You don't want to go over 2.5 inches with a leveling kit/spacer. As for steel vs. polyurethane, it really doesn't matter. And you use OEM length coilover shocks with a spacer lift.
nylon: Lift Kit Nylon B Front 3 5" Rear 2 5" Expedition 03 11 2WD 4WD | eBay
Carbon steel: Carbon Steel Coil Spacer Lift Kit Front 3 5" Rear 2 5" 4x2 2WD 4x4 4WD | eBay
and yes you will need longer shocks. you change the height you have to either change mounting points to keep the same stroke, or a longer stroke to couple with this longer height.
Because they know people won't do their research or listen to others advice and they'll buy them anyways...
Sorry, I meant to type ball joints as obviously a 4x2 doesn't have CV joints up front.
But, he doesn't need longer shocks. The Expy has coilover shocks up front and in the rear. These spacers just bolt on top of the coilovers to achieve a little lift. If he was adding longer or adjustable coilovers, he wouldn't need the spacers.
The 2003-2014 Expy 4x2 and 4x4's have IFS and IRS with coilover shocks. The front IFS is basically identical to the 2004-2014 F-150 4x2 and 4x4's. So his limit, according to members of this site is 2.5 inches. Many 04-14 F-150 owners have found that the 3 inch leveling kits leave the ball joints (and CV joints on 4x4's) at too severe of an angle to last.
