Sponsored by: CARiD
Axle on 4x4
Old Jul 16, 2013 | 01:19 PM
Jonas Winslo's Avatar
Axle on 4x4
I've got a 1998 ext cab 4x4 and i thinking of doing a solid front axle swap and putting the front and rear on triangulated four links with coil overs i hav eno problem with the fab work for the 4 links but i dont know what axle to use any ideas ive seen alot of kits use a dana 44 but out of what and what year? also im not so sure that a 44 will handle the 44's im planning on running.
Old Jul 16, 2013 | 01:23 PM
pizzaman711's Avatar
I'd say one tons with 44's, better to have it and not need it than wish you did it after something breaks.
Old Jul 16, 2013 | 02:15 PM
Just get some Dana 60's and call it a day, and they'll handle it. Just search for old 1 tons, late 70s Fords. What are you gonna be doing with the truck? 44's would probably be alright if you weren't off roading frequently
Old Jul 17, 2013 | 08:51 AM
Contender's Avatar
44s on a full size, you should run a 1-ton frontend.
Which particular Dana 60 will depend on which side your transfer case output is (or will be...if you swap T-cases.)
Fords are driver drop.
GMs are passenger drop.
