2wd suspension lift
2wd suspension lift
I just recently bought a 2004 ford f150 2wd xlt and I plan on putting a 6inch lift on but so far from the very few pictures ive seen 2wd lifted on 6inch aren't very tall. so one does anyone have some more pictures of 2wd lifts on 6 inch suspension or 6in suspension and 3inch body lift? and secondly can anyone help me to figure out which suspension lift is going to be the tallest. im currently looking at the skyjacker due to cost and the two people on here I have searched for and found, said they like it with no problems. is a stage II lift going to be higher or is it still 6inches just adjustable struts? I will probably end up going with a body lift afterwards to get a little more height. and if anyone has fender heights for 6inch lifts on 2wds id appreciate it.
All 6" kits will be just about the same. Stage II kits will come with adjustable struts that will allow you to bump up to 8" later on with the addition of a leveling kit. Fabtech seems to be pretty popular as always. Not too many trucks out there that are 04+ though with body lifts because the install is pretty hard and definitely cost some money if you can't do it yourself. I have a few pictures of 2wd 04-08's in the sticky at the top of this section as well as some links to show off threads for them that you can look through.
I don't understand what the big deal about the body lifts are, I installed one on my chevy Silverado 1500 2 years ago and had no problem it was an 01, is it gonna be a lot harder? ive looked through most of those threads and checked out your sticky, but maybe you can help me what do people mean when they say they added a 2inch AS to their 6inch fabtech?
Body lift difficulty varies by make of the truck and year range. Install for the 97-03 f150s was a lot easier than the 04+ ones. Give the instructions a read over and you'll see if your up to it, performance accessories has all the instructions on their site.
AS means AutoSpring. They make leveling kits. Basically if you have a 6" kit with the adjustable struts (no spacer) and pretty much factory angles you can add a 2" leveling kit to the lift to get 8" total and have the same angles as a truck with a 2" leveling kit which are still good.
If you have a lift with the 6" spacer up front (majority of the stage I kits) you can by leveling struts such as the bilsteins and use them instead of the stock struts and crank them up to 2" to also get 8" total lift overall.
EDIT: now that i see you have to get a shop press to do the spindle, i may go with the procomp just so i don't have to deal with that crap. would this lift be able to use AS or does it come with it i cant tell for sure i think it does. http://4wheelonline.com/Products.asp...roductId=68634
can you take a fender measurement for me front front fenders and is that the cheaper fabtech lift with spacers? i want to get this truck high so im trying to figure out the road i need to take
Also, for reference, the 04-08 F-150 4x2's sit two inches lower than the 4x4's. So a 4x2 with a 6 inch suspension lift is gonna be the same height as a 4x4 with a 4 inch suspension lift. And yes, the 04-08 F-150's are one of the hardest trucks to install a body lift on.
Pics please? And what fabtech kit did you go with? And if you dont mind would you take some fender measurements for me? I went to your garage and your truck is awesome thats exactly what im going for i have a supercab black with tan two tone. If you could just let me know fender heights and which fabtech kit that is, looks like thats what ill be doing haha
Omg im in love with your truck haha i may even copy the bushwacker flares haha your truck is perfect im definetly doing same lift with 2inch spacers, did you install it yourself?
Thanks bud! I appreciate it.
I had a shop install the leveling kit (and the rest of the suspension) I put the bushwackers on with my buddy and his father... It was not a fun or easy thing to do.
Do you have to cut fenders to install them? And whenever you get a chance just measure the fenders for me please id appreciate it
